[postgis-devel] [PostGIS] #1204: Need to generate upgrade script for topology
PostGIS trac at osgeo.org
Wed Sep 21 01:58:59 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  task      |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 strk,
 I wanted to test out the upgrade features of extension, but in order to do
 that, I need an upgrade script for topology.
 I assume we would build it so it has everything but the create type,
 create schema, create table stuff using the perl script we have for
 postgis.  Not sure how to do that.
 We'll need the same for raster, which I think I already have as a ticket.
 The CREATE EXTENSION can also support non-numeric versions, so pre-relese
 I was just going to make the versions
 postgis_topology version 2.0.0a1 etc.  We'd be using ssentially the same
 script to upgrade for each so i'd just need to copy them to files like
 postgis_topology--2.0.0a1--2.0.0a2.sql etc which I'll incorporate in the
 extension make.
 These get daisy chained if it can't find a way to go from v1--v2 with a
 single file.  Though there doesn't seem to be a mechanism to put in a wild
 card version
 e.g. 2.0--2.0.0 which is a bit of a bummer.
 Then when people upgrade, they would run the sql command:
 ALTER EXTENSION postgis_topology UPDATE TO "2.0.0a2";
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1204>
