[postgis-devel] [PostGIS] #1191: move PREPARED_GEOM define in postgis_config.h
PostGIS trac at osgeo.org
Wed Sep 21 19:13:39 PDT 2011
  Reporter:  strk         |       Owner:  pramsey
      Type:  enhancement  |      Status:  reopened
  Priority:  medium       |   Milestone:  PostGIS 2.0.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Do you have debug code stuck somewhere?  my regress is failing
 Run tests: 74
 Failed: 70
 with stuff like this
 using r7880
 --- loader/PointM-w.select.expected     Fri Sep  9 06:49:41 2011
 +++ /tmp/pgis_reg_4740/test_2_out       Wed Sep 21 22:02:12 2011
 @@ -1,3 +1,6 @@
 +NOTICE:  [lwgeom_functions_basic.c:LWGEOM_asEWKT:2296] LWGEOM_asEWKT
 called.
 called.
 called.
  POINTM(0 1 3)
  POINTM(9 -1 -123)
  POINTM(9 -1 -3)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1191#comment:3>
