[postgis-devel] [PostGIS] #1205: Test for ST_AddEdgeNewFaces fails under machine load
PostGIS trac at osgeo.org
Thu Sep 22 01:11:43 PDT 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Changes (by strk):
  * status:  new => assigned
Comment:
 The order by is there, but is based on minx/miny of bounding box, which in
 this case are the same (ouch). The annoying thing is that any ordering
 serves predictability but not performance. Anyway, when an added edge
 splits 2 faces... _which_ face should we add first ? For the
 AddEdgeModFace function we retain the right face, maybe for symmetry we
 should _add_ the right face first in the AddEdgeNewFace..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1205#comment:2>
