[postgis-devel] [PostGIS] #1207: Can't compile under Windows mingw since raster commit
PostGIS trac at osgeo.org
Fri Sep 23 00:16:50 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by strk):
 Either a missing ./configure run (geos_c.h is generated from geos_c.h.in
 at configure time) or a change in the Makefile stripping the correct -I
 out. Check if the file is there (capi/geos_c.h)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1207#comment:3>
