[postgis-devel] [PostGIS] #1207: Can't compile under Windows mingw since raster commit
PostGIS trac at osgeo.org
Fri Sep 23 04:30:15 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 okay I see on closer inspection that the postgis lwgeom_geos.h references
 the one in liblwgeom so they aren't duplicates of each other as I had
 originally thought.  Don't see a similar pattern for raster and copying
 over doesn't help presumably because postgis one has relative paths that
 would not work in raster folder.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1207#comment:5>
