[postgis-devel] [PostGIS] #1207: Can't compile under Windows mingw since raster commit
PostGIS trac at osgeo.org
Sat Sep 24 12:07:54 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Can you try r7889?  I don't think it will help you much as I think I need
 to make one other change to explicitly set GEOS_CPPFLAGS so that gcc knows
 where the GEOS include path is.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1207#comment:9>
