[postgis-devel] KNN and Semantics
    Paragon Corporation
    lr at pcorp.us
    Mon Sep 26 13:19:33 PDT 2011
> So, here's the deal, the KNN search works exclusively against
> the index. So, it only has boxes available to make decisions
> (not entirely true, it actually has the full geometry of the
> query key, but not of the index keys). That means it can
> return an exact answer for point-on-point queries, but for
> everything else it'll be a box approximation. So the n-nearest-boxes.
> There are lots of ways to attack the problem... we can do
> pure nearest-boxes. We could also convert all the boxes to
> points, and do nearest-centroids. This might be easiest to
> explain, potentially. The trouble is, we're going to be
> returning an approximation for everything except points, so
> the question is (in my mind) which approximation is easiest
> to visualize and work with?
Not sure I understand your question Paul?   I don't see how nearest
centroids helps much when you are talking
about largish polygons.  I was thinking this would just make the ST_Expand
like stuff faster? Oh perhaps I misunderstood that.
Thanks,
Regina
