[postgis-devel] [PostGIS] #1207: Can't compile under Windows mingw since raster commit
PostGIS trac at osgeo.org
Mon Sep 26 14:24:10 PDT 2011
  Reporter:  robe            |       Owner:  pracine
      Type:  defect          |      Status:  closed
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Comment(by dustymugs):
 Replying to [comment:7 robe]:
 > for the new raster / raster intersects functionality Bborie added.
 > He uses LWGEOM2GEOS functions etc.
 > Though I'm wondering if this is failing for me for same reason raster
 says my GDAL doesn't have Geos Polygonize support.  Bborie -- does your
 functionality require GDAL be compiled with GEOS?  I assume not but I
 could be mistaken.
 I just wanted to make sure and leave a note about GDAL usage in
 ST_Intersects.  The underlying C function rt_raster_intersects uses no
 GDAL functions.  The plpgsql ST_Intersects function does convert the
 geometry to a raster using ST_AsRaster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1207#comment:16>
