[postgis-devel] [PostGIS] #1218: make fails rev7897 / wheezy
PostGIS trac at osgeo.org
Mon Sep 26 19:18:53 PDT 2011
 Reporter:  darkblueb  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 Debian unstable/wheezy
 (gdal trunk builds fine)
 Linux wheezyvm 3.0.0-1-486 #1 Sat Aug 27 15:56:48 UTC 2011 i686 GNU/Linux
   PostGIS is now configured for i686-pc-linux-gnu
  -------------- Compiler Info -------------
   C compiler:           gcc -g -O2
   C++ compiler:         g++ -g -O2
  -------------- Dependencies --------------
   GEOS config:          /usr/local/bin/geos-config
   GEOS version:         3.4.0dev
   GDAL config:          /usr/local/bin/gdal-config
   GDAL version:         1.9.0
   PostgreSQL config:    /usr/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.1.0
   PROJ4 version:        47
   Libxml2 config:       /usr/bin/xml2-config
   Libxml2 version:      2.7.8
   PostGIS debug level:  0
  -------------- Extensions --------------
   PostGIS Raster:       0.1.6d
   PostGIS Topology:     0.1.1
  -------- Documentation Generation --------
   xsltproc:             /usr/bin/xsltproc
   xsl style sheets:
   dblatex:
   convert:              /usr/bin/convert
 dbb at wheezyvm:/home/shared/srcs_wheezy/postgis_trunk$ make clean && make
 make -C doc clean
 make[1]: Entering directory `/home/shared/srcs_wheezy/postgis_trunk/doc'
 make -C html/image_src clean
 make[2]: Entering directory
 `/home/shared/srcs_wheezy/postgis_trunk/doc/html/image_src'
 make[2]: Leaving directory
 make[1]: Leaving directory `/home/shared/srcs_wheezy/postgis_trunk/doc'
 rm -f postgis.sql postgis_upgrade.sql
 for s in liblwgeom libpgcommon regress postgis loader utils raster
 topology; do \
                 echo "---- Making clean in ${s}"; \
                 make -C ${s} clean || exit 1; \
         done;
 ---- Making clean in liblwgeom
 `/home/shared/srcs_wheezy/postgis_trunk/liblwgeom'
 make -C cunit clean
 `/home/shared/srcs_wheezy/postgis_trunk/liblwgeom/cunit'
 rm -f stringbuffer.lo measures.lo measures3d.lo box2d.lo ptarray.lo
 lwgeom_api.lo lwgeom.lo lwpoint.lo lwline.lo lwpoly.lo lwtriangle.lo
 lwmpoint.lo lwmline.lo lwmpoly.lo lwcollection.lo lwcircstring.lo
 lwcompound.lo lwcurvepoly.lo lwmcurve.lo lwmsurface.lo lwpsurface.lo
 lwtin.lo lwout_wkb.lo lwin_wkb.lo lwout_wkt.lo lwin_wkt_parse.lo
 lwin_wkt_lex.lo lwin_wkt.lo lwutil.lo lwhomogenize.lo lwalgorithm.lo
 lwsegmentize.lo lwprint.lo vsprintf.lo g_box.lo g_serialized.lo g_util.lo
 lwgeodetic.lo lwtree.lo libtgeom.lo lwout_gml.lo lwout_kml.lo
 lwout_geojson.lo lwout_svg.lo lwout_x3d.lo lwgeom_geos.lo
 lwgeom_geos_clean.lo lwgeom_geos_split.lo lwgeom_transform.lo
 lwspheroid.lo
 rm -f liblwgeom.la
 rm -rf .libs
 ---- Making clean in libpgcommon
 `/home/shared/srcs_wheezy/postgis_trunk/libpgcommon'
 make -C cunit clean
 `/home/shared/srcs_wheezy/postgis_trunk/libpgcommon/cunit'
 make[2]: Nothing to be done for `clean'.
 rm -f gserialized_gist.o lwgeom_transform.o lwgeom_pg.o
 rm -f
 rm -f libpgcommon.a
 ---- Making clean in regress
 `/home/shared/srcs_wheezy/postgis_trunk/regress'
 rm -rf /home/shared/srcs_wheezy/postgis_trunk/regress/00-regress-install
 rm -f postgis.sql
 ---- Making clean in postgis
 `/home/shared/srcs_wheezy/postgis_trunk/postgis'
 rm -f postgis-2.0.so   libpostgis-2.0.a
 rm -f postgis.sql uninstall_postgis.sql postgis_upgrade_20_minor.sql
 legacy.sql uninstall_legacy.sql legacy_compatibility_layer.sql
 rm -f lwgeom_debug.o lwgeom_accum.o lwgeom_spheroid.o lwgeom_ogc.o
 lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_estimate.o
 lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_box.o
 lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_geos.o lwgeom_geos_prepared.o
 lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o
 lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_triggers.o lwgeom_dump.o
 lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
 lwgeom_transform.o geography_inout.o gserialized_typmod.o
 gserialized_gist_2d.o gserialized_gist_nd.o geography_btree.o
 geography_estimate.o geography_measurement.o geometry_gist_selectivity.o
 rm -f postgis.sql.in uninstall_postgis.sql.in legacy.sql.in
 uninstall_legacy.sql.in legacy_compatibility_layer.sql.in
 ---- Making clean in loader
 `/home/shared/srcs_wheezy/postgis_trunk/loader'
 make -C cunit clean
 `/home/shared/srcs_wheezy/postgis_trunk/loader/cunit'
 make[1]: Leaving directory `/home/shared/srcs_wheezy/postgis_trunk/loader'
 ---- Making clean in utils
 make[1]: Entering directory `/home/shared/srcs_wheezy/postgis_trunk/utils'
 make[1]: Nothing to be done for `clean'.
 make[1]: Leaving directory `/home/shared/srcs_wheezy/postgis_trunk/utils'
 ---- Making clean in raster
 `/home/shared/srcs_wheezy/postgis_trunk/raster'
 make -C rt_core clean
 `/home/shared/srcs_wheezy/postgis_trunk/raster/rt_core'
 rm -f rt_api.o
 rm -f librtcore.a
 make -C rt_pg clean
 `/home/shared/srcs_wheezy/postgis_trunk/raster/rt_pg'
 rm -f rtpostgis-2.0.so   librtpostgis-2.0.a
 rm -f rtpostgis.sql
 rm -f rt_pg.o
 rm -f rtpostgis.sql.in rtpostgis.sql
 make -C test clean
 `/home/shared/srcs_wheezy/postgis_trunk/raster/test'
 make -C core clean
 make[3]: Entering directory
 `/home/shared/srcs_wheezy/postgis_trunk/raster/test/core'
 rm -f testapi testwkb
 make[3]: Leaving directory
 make -C regress clean
 `/home/shared/srcs_wheezy/postgis_trunk/raster/test/regress'
 rm -f -f rtpostgis.sql
 make -C scripts/python clean
 `/home/shared/srcs_wheezy/postgis_trunk/raster/scripts/python'
 rm -f *.o
 make[1]: Leaving directory `/home/shared/srcs_wheezy/postgis_trunk/raster'
 ---- Making clean in topology
 `/home/shared/srcs_wheezy/postgis_trunk/topology'
 rm -f topology.sql
 rm -f topology.sql.in
 topology; do \
                 echo "---- Making all in ${s}"; \
                 make -C ${s} all || exit 1; \
         done;
 ---- Making all in liblwgeom
 /bin/sh ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall
 -Wmissing-prototypes -I/usr/local/include -DPOSTGIS_GEOS_VERSION=34
 -DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
 ../libtool: 1: eval: base_compile+= gcc: not found
 ../libtool: 1: eval: base_compile+= -g: not found
 ../libtool: 1: eval: base_compile+= -O2: not found
 ../libtool: 1: eval: base_compile+= -fPIC: not found
 ../libtool: 1: eval: base_compile+= -DPIC: not found
 ../libtool: 1: eval: base_compile+= -Wall: not found
 ../libtool: 1: eval: base_compile+= -Wmissing-prototypes: not found
 ../libtool: 1: eval: base_compile+= -I/usr/local/include: not found
 ../libtool: 1: eval: base_compile+= -DPOSTGIS_GEOS_VERSION=34: not found
 ../libtool: 1: eval: base_compile+= -DPOSTGIS_PROJ_VERSION=47: not found
 ../libtool: 1: eval: base_compile+= -c: not found
 ../libtool: 1: eval: CC_quoted+= gcc: not found
 ../libtool: 1: eval: CC_quoted+= g++: not found
 libtool: compile: you must specify a compilation command
 libtool: compile: Try `libtool --help --mode=compile' for more
 information.
 make[1]: *** [stringbuffer.lo] Error 1
 make: *** [all] Error 1
 dbb at wheezyvm:/home/shared/srcs_wheezy/postgis_trunk$ svn up
 U    doc/reference_raster.xml
 Updated to revision 7897.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1218>
