[postgis-devel] KNN Centroid Example
Paragon Corporation lr at pcorp.us
Mon Sep 26 19:51:51 PDT 2011
What algorithm does it use for non-points.  Thought you went with centroid.
IF so how come these don't match or is it centroid of the box?
SELECT ST_Distance(line,pt) as dist, line <-> pt as knn_dist,
    ST_Distance(ST_Centroid(line),pt) As dist_cent
	FROM (SELECT 'SRID=3005;LINESTRING(1011102 450541, 1011103
450641)'::geometry As line,
		 'SRID=3005;POINT(1011102 450541)'::geometry As pt) As foo;
Gives me:
 dist | knn_dist |    dist_cent
    0 |  2500.25 | 50.0024999375613
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: Monday, September 26, 2011 6:59 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] KNN Centroid Example
> So, I did a few KNN queries on my wee voting areas table (8000 polys).
> First the correct answer:
> select st_distance(geom, 'SRID=3005;POINT(1011102 450541)')
> as d,edabbr, vaabbr from va2005 order by d limit 10;
>         d         | edabbr | vaabbr
>                 0 | ALQ    | 128
>  5541.57712511724 | ALQ    | 129A
>  5579.67450712005 | ALQ    | 001
>   6083.4207708641 | ALQ    | 131
>   7691.2205404848 | ALQ    | 003
>  7900.75451037313 | ALQ    | 122
>  8694.20710669982 | ALQ    | 129B
>  9564.24289057111 | ALQ    | 130
>   12089.665931705 | ALQ    | 127
>  18472.5531479404 | ALQ    | 002
> (10 rows)
> Then the KNN raw answer:
> as d,edabbr, vaabbr from va2005 order by geom <->
> 'SRID=3005;POINT(1011102 450541)' limit 10;
>         d         | edabbr | vaabbr
>                 0 | ALQ    | 128
>   24795.264503022 | ALQ    | 124
>  24587.6584922302 | ALQ    | 123
>  26764.2555463114 | ALQ    | 125
> (10 rows)
> Note the misordering in the actual distances and the
> different entries that actually show up in the top 10.
> Finally the hybrid:
> with index_query as (
> as d,edabbr, vaabbr
>   from va2005
>   order by geom <-> 'SRID=3005;POINT(1011102 450541)' limit
> 100) select * from index_query order by d limit 10;
>         d         | edabbr | vaabbr
>                 0 | ALQ    | 128
> (10 rows)
> And again we have the right entries and the right ordering.
> The trouble is the magic number (100) in the subquery. Still,
> it's fast and it uses the index, so, what the hey!
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
