[postgis-devel] [PostGIS] #1218: make fails rev7897 / wheezy
PostGIS trac at osgeo.org
Wed Sep 28 03:38:10 PDT 2011
 Reporter:  darkblueb  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Changes (by strk):
  * owner:  pramsey => strk
  * status:  new => assigned
Comment:
 We've discussed this on the list already, if I'm not wrong.
 The problem was with a system setup error in that the top-level "libtool"
 script we ship (it's in the repository) doesn't have the base_compile
 variable used, so it is _your_ system re-generating it at ./autogen.sh
 time, and it is regenerating a bogus version, which works with bash but
 not with the /bin/sh you have on your system.
 exporting SHELL=/bin/bash should fix the case for you, but you'd better
 either use the version of libtool you find in the repository/package (ie:
 don't run autogen.sh or revert the change of libtool) or fix the
 libtoolize you have in your system (report bug upstream).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1218#comment:3>
