[postgis-devel] [PostGIS] #1218: make fails rev7897 / wheezy
PostGIS trac at osgeo.org
Wed Sep 28 06:38:24 PDT 2011
 Reporter:  darkblueb  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 I've realized there's no libtool script in the repository, but is created
 by ./configure trough the AC_PROG_LIBTOOL macro call deined by
 macros/libtool.m4. The same macro expands the @LIBTOOL@ variable to
 $(SHELL) $(top_srcdir)/libtool.
 Supposedly, the macro is checking if the shell supports the += construct,
 and correctly finding it's _not_ in the darkblueb case (we checked on
 IRC). Despite this recognition, the SHELL variable is still set to /bin/sh
 if no CONFIG_SHELL is set by the user.
 So, workaround would be appending CONFIG_SHELL=/bin/bash or
 SHELL=/bin/bash to the ./configure call.
 A better fix would be making sure the libtool script only uses POSIX
 compliant constructs...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1218#comment:5>
