[postgis-devel] [PostGIS] #1212: [raster]: st_intersects signature change - documentation out of synch
PostGIS trac at osgeo.org
Wed Sep 28 10:24:43 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Replying to [comment:12 pracine]:
 > Replying to [comment:11 dustymugs]:
 > > I like Regina's compromise of turning ST_Intersects(raster, raster,
 int, int) into ST_Intersects(raster, raster) with the integers assumed to
 be 1 and 1.  This is consistent with other raster functions.
 > Yes. This is the default. But what if I want to intersect band 2 of
 raster 1 with band 3 of raster 2?
 ST_Intersects(raster1, raster1band2, raster2, raster2band3)
 > At the beginning there was this discussion about forcing users to use
 ST_Band() to select a particular band... We choose to add a band parameter
 to every function instead. That would be a solution if there is no cost
 but what a change for just a couple of variants.
 We don't need ST_Band() and I don't see any mention of ST_Band outside of
 this...
 > I guess this is the first function taking two raster band. Right? This
 is why we are puzzled so much.
 > On another side: Why is there two versions of _st_intersects(rast
 raster, geom geometry, nband integer DEFAULT NULL) in rtpostgis.sql.in.c?
 I kept the old raster converted to geometry functionality due to edge
 cases where a geometry-geometry intersects test is true while a raster-
 geometry intersects set is false.  Check the Working specs for a visual as
 I detailed out why I kept it.
 So, if ST_Intersects is called with the first argument being a raster...
 ST_Intersects(raster, geometry)
 the geometry is converted to raster and a raster-raster test ensues
 If ST_Intersects is called with a geometry as the first argument...
 ST_Intersects(geometry, raster)
 the raster is converted to a geometry and a geometry-geometry test occurs.
 Definitely check the working specs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1212#comment:13>
