[postgis-devel] [PostGIS] #1212: [raster]: st_intersects signature change - documentation out of synch
PostGIS trac at osgeo.org
Wed Sep 28 10:44:08 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 So we are in agreement?
 The signatures will be
 change: ST_Intersects(rast1,nband1,rast2,nband2) ->
 ST_Intersects(rast1,rast2)
 Put back: ST_Intersects(rast1,nband1,rast2,nband2)
 This keeps consistency and avoids the situation where someone throws in an
 untyped NULL and we then get an ambiguous path like this:
 ST_Intersects(rast,NULL,NULL,2) ;
 I'm almost tempted to say just create a new function name -- call this
 RT_Intersects for raster space intersection (which means operation done in
 raster space)
 and RT_Intersects(raster,geometry)
 RT_Intersects(raster,raster)
 RT_Intersects(raster1,band1,raster2,band2)
 The issue I have with this:
 ST_Intersects(raster, geometry)
 ST_Intersects(geometry, raster)
 As Pierre pointed out is that it is no longer commutative and people will
 assume it is when clearly you are saying one is done in raster space and
 one is done in vector space.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1212#comment:15>
