[postgis-devel] [PostGIS] #1754: Regress failures against edb windows 64-bit builds
PostGIS trac at osgeo.org
Wed Apr 4 15:44:17 PDT 2012
 Reporter:  robe                   |       Owner:  pramsey
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  postgis                |     Version:  2.0.x
 Keywords:  mingw64,windows 64bit  |
 I guess I had neglected to do make check against edb builds and was doing
 it on my compiled versions.
 Sadly I'm seeing a lot of crashes here -- though not sure if much can be
 done about it.
 On 9.1.3 VC++ compiled (note mingw64 is more or less okay except for the
 rounding issues)
  PostgreSQL 9.1.3, compiled by Visual C++ build 1500, 64-bit
  Postgis 2.0.0 - r9605 - 2012-04-04 15:31:29
    GEOS: 3.3.3-CAPI-1.7.4
    PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  loader/Point ....................... ok
  loader/PointM ....................... ok
  loader/PointZ ....................... ok
  loader/MultiPoint ....................... ok
  loader/MultiPointM ....................... ok
  loader/MultiPointZ ....................... ok
  loader/Arc ....................... ok
  loader/ArcM ....................... ok
  loader/ArcZ ....................... ok
  loader/Polygon ....................... ok
  loader/PolygonM ....................... ok
  loader/PolygonZ ....................... ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint .... failed (wkt test: diff expected obtained:
 /tmp/
 pgis_reg/test_18_diff)
  loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
 output: /tmp
 /pgis_reg/loader.err)
  loader/ReprojectPts .... failed ( wkt test: running shp2pgsql output:
 /tmp/pgis
 _reg/loader.err)
  loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql output:
 /tmp/
  loader/Latin1 .... ok
  binary .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  out_geometry .. ok
  out_geography .. ok
  in_gml .. failed (diff expected obtained: /tmp/pgis_reg/test_52_diff)
  in_kml .. failed (diff expected obtained: /tmp/pgis_reg/test_53_diff)
  iscollection .. failed (diff expected obtained:
 /tmp/pgis_reg/test_54_diff)
  regress_ogc .. failed (diff expected obtained:
 /tmp/pgis_reg/test_55_diff)
  regress_ogc_cover .. failed (diff expected obtained:
 /tmp/pgis_reg/test_56_diff
  regress_ogc_prep .. failed (diff expected obtained:
 /tmp/pgis_reg/test_57_diff)
  regress_bdpoly .. failed (diff expected obtained:
 /tmp/pgis_reg/test_58_diff)
  regress_proj .. failed (diff expected obtained:
 /tmp/pgis_reg/test_59_diff)
  regress_management .. failed (diff expected obtained:
 /tmp/pgis_reg/test_60_dif
 f)
  dump .. ok
  dumppoints .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. ok
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  in_geojson .. ok
  uninstall .. ok (3857)
 Run tests: 85
 Failed: 13
 make: *** [check] Error 13
 The in_gml one is the result of a crash. I suspect a lot of the others
 that follow are server trying to stand back up from crahs. I vaguely
 remember having this issue with my 32-bit build before but can't recall if
 we changed something to fix the issue and it was a memory leak.
 Raster looks good though comes thru with flying colors on both vc++ and
 mingw64 pg :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1754>
