[postgis-devel] [PostGIS] #1754: Regress failures against edb windows 64-bit builds
PostGIS trac at osgeo.org
Wed Apr 4 16:13:56 PDT 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  postgis                |     Version:  2.0.x
 Keywords:  mingw64,windows 64bit  |
Comment(by robe):
 Okay things look way better if I take the in_gml test out so it really is
 just in_gml failing.  The others are harmless rounding issues (or the
 reporject failing only when in battery of tests) I see compiling against
 regular mingw64 compiled postgres.
  PostgreSQL 9.1.3, compiled by Visual C++ build 1500, 64-bit
  Postgis 2.0.0 - r9605 - 2012-04-04 15:31:29
    GEOS: 3.3.3-CAPI-1.7.4
    PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  loader/Point ....................... ok
  loader/PointM ....................... ok
  loader/PointZ ....................... ok
  loader/MultiPoint ....................... ok
  loader/MultiPointM ....................... ok
  loader/MultiPointZ ....................... ok
  loader/Arc ....................... ok
  loader/ArcM ....................... ok
  loader/ArcZ ....................... ok
  loader/Polygon ....................... ok
  loader/PolygonM ....................... ok
  loader/PolygonZ ....................... ok
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint .... failed (wkt test: diff expected obtained:
 pgis_reg/test_18_diff)
  loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
 output:
 /pgis_reg/loader.err)
  loader/ReprojectPts .... failed ( wkt test: running shp2pgsql output:
 /tmp
 _reg/loader.err)
  loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql output:
  loader/Latin1 .... ok
  binary .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  out_geometry .. ok
  out_geography .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. ok
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  in_geojson .. ok
  uninstall .. ok (3857)
 Run tests: 84
 Failed: 4
 make: *** [check] Error 4
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1754#comment:3>
