[postgis-devel] [PostGIS] #1707: Regress on topology running make check - r9529
PostGIS trac at osgeo.org
Thu Apr 5 05:51:14 PDT 2012
 Reporter:  sindile   |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by sindile):
 @strk: i have tried it on the recently released postgis 2.0
 >>>psql --set ON_ERROR_STOP=1 -f topology/topology.sql testdb
 CREATE SCHEMA
 BEGIN
 psql:topology/topology.sql:215: NOTICE:  CREATE TABLE will create implicit
 sequence "topology_id_seq" for serial column "topology.id"
 psql:topology/topology.sql:215: NOTICE:  CREATE TABLE / PRIMARY KEY will
 create implicit index "topology_pkey" for table "topology"
 psql:topology/topology.sql:215: NOTICE:  CREATE TABLE / UNIQUE will create
 implicit index "topology_name_key" for table "topology"
 CREATE TABLE
 CREATE FUNCTION
 psql:topology/topology.sql:316: NOTICE:  CREATE TABLE / PRIMARY KEY will
 create implicit index "layer_pkey" for table "layer"
 psql:topology/topology.sql:316: NOTICE:  CREATE TABLE / UNIQUE will create
 implicit index "layer_schema_name_table_name_feature_column_key" for table
 "layer"
 CREATE TABLE
 CREATE TRIGGER
 CREATE TYPE
 CREATE TYPE
 CREATE DOMAIN
 ALTER DOMAIN
 ALTER DOMAIN
 ALTER DOMAIN
 CREATE DOMAIN
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE CAST
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 psql:topology/topology.sql:4197: NOTICE:  aggregate
 topology.topoelementarray_agg(topology.topoelement) does not exist,
 skipping
 DROP AGGREGATE
 CREATE AGGREGATE
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE TYPE
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
 CREATE FUNCTION
                      addtosearchpath
  topology has been added to end of database search_path
 (1 row)
 COMMIT
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1707#comment:10>
