[postgis-devel] [PostGIS] #1707: Regress on topology running make check - r9529
PostGIS trac at osgeo.org
Thu Apr 5 07:00:39 PDT 2012
 Reporter:  sindile   |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by robe):
 sindile can you confirm that the user account you are testing with doesn't
 have it's own custom search path.  I suspect it might and is overriding
 the database search path.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1707#comment:16>
