[postgis-devel] trunk == 2.0.1
Angelos Tzotsos
gcpp.kalxas at gmail.com
Thu Apr 5 17:47:40 PDT 2012
ok, I am looking into this. I need to test a few things.
Angelos
On 04/06/2012 03:31 AM, Paul Ramsey wrote:
> The key here is that folks can just go "upgrade postgis" (whatever the
> command it) and end up w/ a non-working system. We want them to go
> "get postgis2" and then go through the migration steps. Is that
> doable?
> P
> On Thu, Apr 5, 2012 at 5:30 PM, Angelos Tzotsos<gcpp.kalxas at gmail.com> wrote:
>> Hi Chris,
>> Thanks for your suggestion.
>> Actually I did something different here:
>> The published name of the package is the same, so there is a
>> postgis-1.5.3.rpm and a postgis-2.0.0.rpm at the same time.
>> The name postgis1 is just internal to OBS. Using 'postgis2' would have the
>> same result...
>> Angelos
>> On 04/06/2012 03:12 AM, Chris Hodgson wrote:
>>> I think that releasing the postgis 2.0.0 package as "postgis2" is a better
>>> approach, as you really don't want people to be able to automatically
>>> replace their postgis 1.5 with postgis 2.0.0.
>>> Creating postgis1 packages will just force everyone to go through this
>>> nasty process... that said, for anyone who has already "upgraded" to 2.0.0
>>> using your packages, they will need the postgis1 package to go back and fix
>>> things.
>>> What a mess!
>>> Chris
>>> On 12-04-05 04:49 PM, Angelos Tzotsos wrote:
>>>> I have now created 'postgis1' as a branch of 1.x
>>>> Hope to get this working in a while.
>>>> On 04/06/2012 02:38 AM, Paul Ramsey wrote:
>>>>> Yeah, maybe it needs to be packaged as 'postgis2' so that people can
>>>>> install both versions simultaneously to make upgrading simpler...?
>>>>> On Thu, Apr 5, 2012 at 3:31 PM, Angelos Tzotsos<gcpp.kalxas at gmail.com>
>>>>> wrote:
>>>>>> Hi Paul,
>>>>>> Thanks for the heads up.
>>>>>> A possible work around would be to host some 1.5.x binaries on another
>>>>>> repository, since OpenBuildService does not archive old versions of the
>>>>>> rpms.
>>>>>> Since OBS uses version control, I can get the latest 1.5.x postgis
>>>>>> version
>>>>>> up and running elsewhere. Perhaps we could advertise this solution in
>>>>>> postgis documentation somewhere, so that people can see it?
>>>>>> I will see if there can be any name convention (like postgis1) for the
>>>>>> old
>>>>>> version, but this could lead to some other troubles...
>>>>>> I will get back with a plan for this.
>>>>>> Regards,
>>>>>> Angelos
>>>>>> On 04/05/2012 11:55 PM, Paul Ramsey wrote:
>>>>>>> Angelos, see this
>>>>>>> http://gis.stackexchange.com/questions/22945/postgis-2-0-upgrade-problem-with-postgres-data
>>>>>>> Is there any way to warn people as they upgrade, because 2.0 is not
>>>>>>> backwards compatible with 1.5. They need to dump their database before
>>>>>>> they upgrade and run it through postgis_restore.pl while loading it
>>>>>>> back into 2.0.
>>>>>>> P.
>>>>>>> On Tue, Apr 3, 2012 at 1:17 PM, Angelos Tzotsos<gcpp.kalxas at gmail.com>
>>>>>>> wrote:
>>>>>>>> OK, no one can hear us :)
>>>>>>>> On 04/03/2012 11:15 PM, Paul Ramsey wrote:
>>>>>>>>> Yes. Sssssh :)
>>>>>>>>> thanks,
>>>>>>>>> P
>>>>>>>>> On Tue, Apr 3, 2012 at 1:15 PM, Angelos
>>>>>>>>> wrote:
>>>>>>>>>> Hi Paul,
>>>>>>>>>> I assumed this is the final:
>>>>>>>>>> http://postgis.org/download/postgis-2.0.0.tar.gz
>>>>>>>>>> Angelos
>>>>>>>>>> On 04/03/2012 11:11 PM, Paul Ramsey wrote:
>>>>>>>>>>> Are all the versions numbers correct? What did you package off of?
>>>>>>>>>>> I
>>>>>>>>>>> haven't released the tarball yet...
>>>>>>>>>>> P.
>>>>>>>>>>> On Tue, Apr 3, 2012 at 1:09 PM, Angelos
>>>>>>>>>>> wrote:
>>>>>>>>>>>> On 04/03/2012 10:39 PM, Paul Ramsey wrote:
>>>>>>>>>>>>> Devs,
>>>>>>>>>>>>> I have tagged 2.0.0. I have not branched a 2.0 yet. I would like
>>>>>>>>>>>>> to
>>>>>>>>>>>>> hold 2.0 development on trunk until we do a 2.0.1 release. At
>>>>>>>>>>>>> that
>>>>>>>>>>>>> point we can create a 2.0 branch and bring new features online
>>>>>>>>>>>>> in
>>>>>>>>>>>>> trunk.
>>>>>>>>>>>>> Uploading and preparing text now for release announcement.
>>>>>>>>>>>>> P.
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> postgis-devel mailing list
>>>>>>>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>>>>>>>>>> Hi all,
>>>>>>>>>>>> I have completed packaging of v2.0 for openSUSE.
>>>>>>>>>>>> Waiting the announcement to release the rpms :)
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Angelos
>>>>>>>>>>>> Angelos Tzotsos
>>>>>>>>>>>> Remote Sensing Laboratory
>>>>>>>>>>>> National Technical University of Athens
>>>>>>>>>>>> http://users.ntua.gr/tzotsos
>>>>>>>>>> Angelos Tzotsos
>>>>>>>> Angelos Tzotsos
>>>>>> Angelos Tzotsos
>> Angelos Tzotsos
Angelos Tzotsos
