[postgis-devel] [PostGIS] #1759: shp2pgsql st_transform not unique requires casting
PostGIS trac at osgeo.org
Thu Apr 5 19:38:32 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 shp2pgsql is emitting code like this
 ST_Transform('0101000020E61000009A081B9E5E9557C0006F8104C51F4440', 900913)
 If you use ST_Transform.  However if you have raster installed in your db,
 you get an ST_Transform is not unique notice, because raster also has an
 ST_Transform function.
 This needs to be changed to
 ST_Transform('0101000020E61000009A081B9E5E9557C0006F8104C51F4440'::geometry,
 900913);
 See user posting:
 http://postgis.refractions.net/pipermail/postgis-
 users/2012-April/033534.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1759>
