[postgis-devel] [PostGIS] #1468: shp2pgsql-gui append/create/delete/prepare options sitting behind table column
PostGIS trac at osgeo.org
Fri Apr 6 10:11:39 PDT 2012
column
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  low            |   Milestone:  PostGIS 2.0.1
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by mcayland):
 I'm still exactly unsure about what you're seeing here, or at least I
 can't reproduce it here. What version of GTK are you using? And would it
 be possible to attach a screenshot so I can try and interpret what you are
 seeing?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1468#comment:3>
