[postgis-devel] [PostGIS] #1760: crash if gdal_data env variable not in place on windows 64
PostGIS trac at osgeo.org
Sat Apr 7 01:34:43 PDT 2012
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.1
Component:  raster          |     Version:  2.0.x
 Keywords:  win64, mingw64  |
 I was doing a spatial query with ST_Clip and I neglected to put in the
 GDAL_DATA environment variable before hand.
 The query crashed the service and logs show this:
 ERROR 4: Unable to open EPSG support file gcs.csv.
 Try setting the GDAL_DATA environment variable to point to the
 directory containing EPSG csv files.
 2012-04-07 08:03:57 EST LOG:  server process (PID 3144) was terminated by
 exception 0xC0000005
 After registering the variable things work fine -- so might be one of
 those null character issues similar to what we had with null proj4text
 strings.
 This is on a windows 2008 R2 64-bit running 64-bit PostgreSQL/PostGIS
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1760>
