[postgis-devel] [PostGIS] #1763: topology on pgsql 8.4?
PostGIS trac at osgeo.org
Sun Apr 8 02:32:07 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 Could be a search_path issue.
 topology/sql/topogeometry/totopogeom.sql.in.c is missing full-
 qualification for the calls.
 Could you check if replacing the call to add "topology." prefix fixes your
 issue ?
 (I think it's a bug not to fully-qualify)
 Also, check your search_path.
 And check also postgis_full_version for "needs upgrade" messages.
 Note I'm on 8.4 so it's well tested there (beside the search_path issue).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1763#comment:1>
