[postgis-devel] [PostGIS] #1764: overviews not marked as same alignment though main table is
PostGIS trac at osgeo.org
Mon Apr 9 06:05:34 PDT 2012
 Reporter:  robe    |       Owner:  pracine
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
 I'm guessing this is a rounding issue.  I loaded up some 1-meter DEMS and
 chunked them to 128x128 and also created over views.  So my main table has
 about 100,000 records.
 The main table got registered as same alignment = true,
 the level 2 got registered also as same alignment = true, but the level 3
 dems came in as same alignment = false.
 I would assume if the core table was same alignment, then all the
 overviews should be as well -- no?
 This is testing on PostGIS 2.0.0 64-bit on windows 2008 R2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1764>
