[postgis-devel] [PostGIS] #1764: overviews not marked as same alignment though main table is
PostGIS trac at osgeo.org
Mon Apr 9 16:11:53 PDT 2012
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  assigned
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Changes (by dustymugs):
  * owner:  pracine => dustymugs
  * status:  new => assigned
Comment:
 You're probably right about this being a rounding issue.  We need to add a
 tolerance parameter for the same alignment check.  I'll see if I can
 reproduce this using some of my rasters.  Might be a good time to play
 with DEM datasets.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1764#comment:1>
