[postgis-devel] [PostGIS] #1735: ST_MakeValid: exception on geometry
PostGIS trac at osgeo.org
Tue Apr 10 08:43:52 PDT 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 Alright the invalid-result-from-UnaryUnion was finally fixed in GEOS and
 with that fix I can get a valid result from ST_MakeValid:
 strk=# select ST_Summary(ST_MakeValid('MULTIPOLYGON(((1725063 4819121,
 1725104 4819067, 1725060 4819087, 1725064.14183882
 4819094.70208557,1725064.13656044 4819094.70235069,1725064.14210359
 4819094.70227252,1725064.14210362 4819094.70227252,1725064.13656043
 4819094.70235069,1725055. 4819094, 1725055 4819094, 1725055 4819094,
 1725063 4819121)))'));
               st_summary
  GeometryCollection[B] with 2 elements
    Polygon[] with 2 rings
     ring 0 has 12 points
     ring 1 has 4 points
    LineString[] with 2 points
 (1 row)
 Let's keep this ticket open until GEOS-3.3.4 is out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1735#comment:24>
