[postgis-devel] [PostGIS] #1714: totopogeom - can't add multipolygo
PostGIS trac at osgeo.org
Tue Apr 10 10:52:39 PDT 2012
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 The damage occurs near a very tiny hole in your polygon:
 [[Image(nei_hole.png)]]
 [[Image(nei_hole_big.png)]]
 The distance between the two closest red points there is around 1.6,
 which is bigger than your tolerance, so that doesn't need to be the
 reason...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1714#comment:3>
