[postgis-devel] [PostGIS] #1708: postgis_restore not converting ndims and srid constraints to st_...
PostGIS trac at osgeo.org
Thu Apr 12 03:44:05 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  assigned
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 Confirmed for ndims, not for st_srid.
 Could you please write the output from postgis_restore.pl into a file and
 then grep CHECK in it ?
 My output:
 $ grep CHECK backup.sql
     CONSTRAINT enforce_dims_the_geom CHECK ((ndims(the_geom) = 2)),
     CONSTRAINT enforce_geotype_the_geom CHECK (((geometrytype(the_geom) =
 'MULTIPOLYGON'::text) OR (the_geom IS NULL))),
     CONSTRAINT enforce_srid_the_geom CHECK ((st_srid(the_geom) = 2249))
 You can see "enforce_srid_the_geom" CHECK was correctly rewritten
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1708#comment:2>
