[postgis-devel] [PostGIS] #1694: PostGIS 2.0.0 does not build with clang
PostGIS trac at osgeo.org
Thu Apr 12 08:46:26 PDT 2012
 Reporter:  vince    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Vince: did you try r9639 ? I'm using CPPBIN to build an SQLPP, so CPP is
 only used IFF a `cpp` executable isn't found.
 You'll need to run ./autogen.sh and ./configure again after an svn up..
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1694#comment:20>
