[postgis-devel] [PostGIS] #1468: shp2pgsql-gui table column schema get shifted
PostGIS trac at osgeo.org
Sun Apr 15 08:52:15 PDT 2012
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  low            |   Milestone:  PostGIS 2.0.1
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by mcayland):
 Now I see - I misunderstood this bug by thinking it was just a visual
 artifact under Windows. Using the screenshots above, I've managed to
 duplicate this and commit a fix as r9644. Can you check at your end and
 close the bug if you're happy the fix works during your testing?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1468#comment:7>
