[postgis-devel] [PostGIS] #1779: Make install is not installing comments sql files
PostGIS trac at osgeo.org
Tue Apr 17 06:23:09 PDT 2012
 Reporter:  jomarlla               |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 "make" builds the comments sql files but "make install" does not install
 it. One can use "make docs-install" but it shouldn't be necessary.
 - postgis_comments.sql
 - raster_comments.sql
 - topology_comments.sql
 The installation of PostGIS 2.0 from repositories for OpenSuse 12.1
 (http://download.opensuse.org/repositories/Application:/Geo/) is not
 including these comments either.
 Didnt check in other Linux distros.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1779>
