[postgis-devel] [PostGIS] #1781: Window installer freezes with blank password
PostGIS trac at osgeo.org
Tue Apr 17 23:59:47 PDT 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.1
Component:  postgis        |     Version:  2.0.x
 Keywords:                 |
Comment(by robe):
 hmm so yours could be an isolated incident because you had dlls in use?  I
 tried on a windows 2003 64-bit and a 2008 64-bit the 32-bit and it seemed
 to run okay on both of those.
 Regarding the proceeding with the wrong password.  That's expected if you
 have your local set to trust.  Then it actually doesn't matter which
 password you type in since postgresql will accept it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1781#comment:4>
