[postgis-devel] [PostGIS] #1782: [raster] rtpg_getSR fails for any spatial reference system not in EPSG.
PostGIS trac at osgeo.org
Wed Apr 18 17:34:21 PDT 2012
  Reporter:  kempisty  |       Owner:  dustymugs
      Type:  defect    |      Status:  reopened
  Priority:  medium    |   Milestone:  PostGIS 2.0.1
 Component:  raster    |     Version:  2.0.x
Resolution:            |    Keywords:
Changes (by kempisty):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 r9647 takes care of the segfault.  There is still the matter of handling
 the query into spatial_ref_sys.  If auth_name isn't 'EPSG', the logic
 still returns an error without trying proj4text or srid.
 At the moment, with the default contents of spatial_ref_sys, that's only a
 problem for srid=900913, auth_name="spatialreferencing.org".  I suppose
 those people can use srid=3857 instead.  In my case, for a custom srs with
 no auth_name, I will still get the error.  rtpg_getSR will never try my
 proj4text or srtext strings in GDAL.
 It looks like GDAL's SetFromUserInput() will take EPSG: as well as EPSGA:
 and ESRI: and several other versions of shorthand.  I'm not sure how many
 other people add their own entries into spatial_ref_sys.  If they do, and
 if the auth_name is ESRI, or EPSGA, or null, they'll run into this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1782#comment:3>
