[postgis-devel] [PostGIS] #1785: Can't compile under mingw 64-bit anymore
PostGIS trac at osgeo.org
Sun Apr 22 12:43:48 PDT 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.1
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by mcayland):
 Right so the culprit must be this commit:
 http://trac.osgeo.org/postgis/changeset/9639/.
 What does typing just "cpp" at the MingW terminal give you on both 32-bit
 and 64-bit? I'm guessing that perhaps it doesn't exist on 64-bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1785#comment:4>
