[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
PostGIS trac at osgeo.org
Mon Apr 23 23:28:00 PDT 2012
 Reporter:  robe             |       Owner:  pramsey
     Type:  defect           |      Status:  new
 Priority:  medium           |   Milestone:  PostGIS 1.5.4
Component:  postgis          |     Version:  1.5.X
 Keywords:  windows, 64-bit  |
Comment(by strk):
 Ah, ok, it's the small test paul provided showing it clearly:
 select st_summary(st_union(geom))
 from (
  select (st_dump('SRID=4326;MULTIPOLYGON(((0 0, 1 1, 1 0, 0 0)),((4 4, 4
 5, 5 5, 4 4)))'::geometry)).geom
 ) as foo;
 Still happens as of 1.5.4SVN. Culprit is ST_Union. Any system is affected,
 not only windows.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:24>
