[postgis-devel] [PostGIS] #1788: run_test hangs on MSYS
PostGIS trac at osgeo.org
Tue Apr 24 12:56:08 PDT 2012
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by pramsey):
 The problem is "too many stdout pipes". Basically once you get to 16,
 things hang. The first time I fixed this was by turning a pile of sed
 calls into a single call. Then strk added a new grep call recently and
 that put us over the top this time. So I have turned some greps into
 equivalent single patterns.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1788#comment:1>
