[postgis-devel] [PostGIS] #1794: make check under mingw doesn't work
PostGIS trac at osgeo.org
Mon Apr 30 09:56:40 PDT 2012
 Reporter:  pramsey  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 The code to figure out the root directory to install into doesn't work in
 the latest mingw variants. Same problem as existed in 2.0.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1794>
