[postgis-devel] [PostGIS] #1794: make check under mingw doesn't work
PostGIS trac at osgeo.org
Mon Apr 30 11:05:54 PDT 2012
  Reporter:  pramsey  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 1.5.4
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:
Comment(by robe):
 FWIW this change breaks old mingw variants. Not that it matters except
 that I can't use the newer mingw's to compile the 32-bit chain because of
 the GEOS issues (with the newer GCC) without having to install a legacy
 VStudio VC++ Express companion.  But I've gotten into the habit of hacking
 up my scripts to function, so carry on.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1794#comment:3>
