[postgis-devel] [PostGIS] #1121: populate_geometry_columns using deprecated functions
PostGIS trac at osgeo.org
Mon Apr 30 19:14:54 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Changes (by robe):
  * owner:  robe => pramsey
Comment:
 Fixed at r9707
 I added a regression test for this as well more or less copied from 2.0
 branch.  I also revised DropGeometryColumns to use DROP TABLE IF EXISTS
 instead of DROP TABLE.  Our minimum for 1.5 is 8.3 and DROP TABLE IF
 EXISTS has been supported since 8.2
 The only thing left is to add this new test to regress/Makefile.in
 Paul, can you do that for me?
 I'm afraid to commit my version of the file since mine is a hacked up
 version because of issues I described in #1794
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1121#comment:3>
