[postgis-devel] [PostGIS] #1944: Extensions Migration path from 2.1.0 to 2.1.0
PostGIS trac at osgeo.org
Fri Aug 3 04:18:04 PDT 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 I'm planning to implement my workardoun to encourage testing of pre-
 versioned builds.
 The plan -- always have a
 PostGIS-2.1.0SVN--PostGIS-2.10SVNnext.sql
 PostGIS-2.1.0SVNnext--PostGIS-2.1.0SVN.sql
 As I describe here:
 http://www.bostongis.com/blog/index.php?/archives/190-How-to-Use-PostGIS-
 Extensions-to-upgrade-to-non-released-PostGIS-versions.html
 So that way people who are using the extensions model, but also want to be
 able to upgrade non-released versions will play a yoyo game of
 ALTER EXTENSION postgis UPDATE TO "2.1.0SVNnext";
 ALTER EXTENSION postgis UPDATE TO "2.1.0SVN";
 Before I do this, we really got to fix the upgrade scripts (since they are
 broken both for extension and for 9.0 builds if you are coming from 2.0)
 so they actually work for early 2.1.0 releases and 2.0.+ releases. Without
 this I feel we aren't going to get any serious testing which is essential.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1944>
