[postgis-devel] [PostGIS] #1948: Can't upgrade from 2.0.1 to 2.1 with extensions
PostGIS trac at osgeo.org
Mon Aug 6 06:41:04 PDT 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
 I thought I had tested this, but guess not.  This just effects extensions.
 If I'm on 2.0.1 and I do this:
 ALTER EXTENSION postgis UPDATE TO "2.1.0SVN";
 I get "cannot drop type summarystats because extension postgis depends on
 it".
 To get around these issues, I explicitly add these drop entries to
 extensions\postgis\sql_bits\remove_from_extension.sql.in
 Ideally it would be nice to have a single location for this so we don't
 have to state it twice, but for now I'll do the same for these dropped
 types.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1948>
