[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Fri Aug 17 02:43:15 PDT 2012
  Reporter:  twain    |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 1.5.5
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  ST_contains memory
Changes (by RustyMuppet):
  * status:  closed => reopened
  * resolution:  fixed =>
  * milestone:  PostGIS 2.0.0 => PostGIS 1.5.5
Comment:
 I had this problem using postgis 1.5.5 (postgresql 9.1.4) with
 st_intersects in the where clause.
 Can we get this fix backported to 1.5 please.
 Thanks
 Darren
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:22>
