[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Fri Aug 17 03:04:18 PDT 2012
  Reporter:  twain    |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 1.5.5
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  ST_contains memory
Comment(by strk):
 The 1.5 branch is in horrible conditions at this very moment, see ticket
 #1954 -- need a succeeding testsuite before adding anything can be
 committed (any commit in 1.5 needs careful checking)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:23>
