[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Fri Aug 17 05:36:41 PDT 2012
  Reporter:  twain    |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 1.5.5
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  ST_contains memory
Comment(by strk):
 Ok, could you please test r10186, Darren ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:24>
