[postgis-devel] [PostGIS] #1955: Exception when 2 edges passed to ST_ModEdgeHeal() that are attached to the same 2 nodes
PostGIS trac at osgeo.org
Fri Aug 17 05:41:25 PDT 2012
same 2 nodes
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 This is tricky, why do you think "the other node" should be removed ?
 Shouldn't _both_ nodes be removed instead ?
 I'm afraid the SQL/MM document doesn't have any prescription about this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1955#comment:1>
