[postgis-devel] [PostGIS] #1953: ST_MakeValid don't work
PostGIS trac at osgeo.org
Fri Aug 17 05:44:46 PDT 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.1.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Changes (by strk):
  * owner:  pramsey => strk
  * status:  new => assigned
Comment:
 Sounds like a regression, also ST_IsValid is affected. Should return a
 boolean and instead throws an exception. I'm so sure it got fixed in the
 past ?!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1953#comment:1>
