[postgis-devel] [PostGIS] #1955: Exception when 2 edges passed to ST_ModEdgeHeal() that are attached to the same 2 nodes
PostGIS trac at osgeo.org
Fri Aug 17 09:24:48 PDT 2012
same 2 nodes
 Reporter:  wimned    |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 I suspect there's another case which isn't tested: 2 edges both having  a
 single, common, node.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1955#comment:5>
