[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Sun Aug 19 15:34:52 PDT 2012
  Reporter:  twain    |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 1.5.6
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:  ST_contains memory
Changes (by strk):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Confirmed fix: http://postgis.refractions.net/pipermail/postgis-
 users/2012-August/035088.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/547#comment:26>
