[postgis-devel] [PostGIS] #1959: Upgrading with extensions getting a row is too big
PostGIS trac at osgeo.org
Mon Aug 20 06:48:25 PDT 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 okay only seems to be an issue with extension script and logs aren't very
 helpful.
 Would be good if non-windows folks can try the same to see if its just a
 windows issue. Last time I saw this kind of issue was a collation bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1959#comment:2>
