[postgis-devel] [PostGIS] #1958: ST_Intersects(geography) returns incorrect result when called multiple times
PostGIS trac at osgeo.org
Mon Aug 20 09:17:50 PDT 2012
times
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  postgis        |     Version:  2.0.x
 Keywords:                 |
Comment(by pramsey):
 Example that dodges having force the cache:
 WITH objs AS
  SELECT
   'LINESTRING(22.88333 41.96667,21.32667 42.13667)'::geography AS line,
   'POLYGON((22.94472 41.34667,22.87528 41.99028,22.87389 41.98472,22.87472
 41.98333,22.94472 41.34667))'::geography AS border
 SELECT ST_Distance(line, border), _ST_DistanceTree(line, border)
 FROM objs;
 Basically we have a big disagreement about distance, presumably because
 the containment test is failing on the tree side.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1958#comment:1>
